Electro or Co2 ?
Moderators: minipower, Patrick, Lg tweewielers, DMZohrab
Electro or Co2 ?
What kind of welder have you guys used, for welding your frame?
A electro welder, or co2, can both be used? Which one is the best?
Markie
Bericht door Markie »
You beter can welder with Co2
It's much easier, and its nicer then electro!
And its much stronger!!
John_W
Bericht door John_W »
Michael,
basicly is doesn't matter which type of welding you plan to use. The strenhgt of a correct welded frame is for each type of welding the same (when you are the expert). I did all my welding based on CO2 with a nice result (to my opinion :D ).
But be carefull with CO2. You can create very nice looking bad welds which have no strength. Please try a little bit on restmaterial of the same size that you plan to use.
succes with your project
I dousn't matter if you're a good welder you can make a nice weld with electro ore Co2. I learned on school that electro was the strongest because the burning was deeper in to the steel if you knwo wath i mean. Just use wath you're the best in
