I search owner of this minibike.
- doraimontv
Good days.
http://www.minibike.nl/handleidingen/moamb.php
In that e-mail I can locate the builder of this minibike?
A greeting from Spain.
- doraimontv
Thank you for your rapid response.
I am a child of 14 years and want(love) to do a like this minibike to me.
It(He,She) likes to me since this I throw(add) the chassis, I want to make it equal, but I do not have measurements.
Because of it queria to speak with, to see if it(he,she) can give me some measurement.
You can say the averages to your me?
You can say to your me where to look at the averages?
This text to translate it in a translator in line, excuses for the failures.
hola, cómo es usted que hace Bici de Niza isent:P... su una bici verry del dificult para hacerle puede hacer mejor uno con un motor del maxi del puch Saluda
Comprendé Poffabor
* Lg *
Comprendé Poffabor
* Lg *
- doraimontv
Already I have the block of piaggio finished, and been late one month in to modify it.
It and modified with the help of Hank's photos.
If me decis since I can it(he,she) puts photos here, I teach(show) the block to you of piaggio.
I have a lot of experience welding.
Podeis measurements to give myself?
Thank you for yours help.
kijk Hank je bent zelfs al toepasselijk in spanje ..doraimontv schreef:Already I have the block of piaggio finished, and been late one month in to modify it.
wou dat ik zo belangrijk was..
- üntiej#21
First: you must have all the parts to build the bike.
Like: engine (piaggio), exaust, front-fork, wheels, brakes, seat, chain.
Then you have to put your engine and wheels and frontvork with the right angels and distances, into a home-made houlder witch you can use to make your frame around it ( Just like HANK )...
And, the last thing you do, is to make a Frame around the parts you have sett up. ( my english isn`t so very good )...
Make sure the chain is right to your rear-wheel, and your Front-fork is at the right angle.
Good Luck.
( btw, i have moved your subject to "Zelfbouw" , when you have pictures and more specifications, you can make a subject at the "paddock" )
Good Luck.
Laatst gewijzigd door üntiej#21 op ma 03 apr 2006, 20:16, 1 keer totaal gewijzigd.
ésta es página del paddoc del te de la madeja
http://www.minibike-forum.nl/viewtopic.php?t=1893
* Lg *
* Lg *
- üntiej#21
And i can give you something else:
its my own Piaggio engine.. Maybe you can use it
http://www.minibike-forum.nl/viewtopic.php?t=6264
- doraimontv
Untiej Mini Racing:
-if, I have everything except the seat
-If, like doing it, in the photos it is explained very well.
-For this, the chassis, needs to me the measures, the degrees of the direction, the height of the seat, the wheelbase, the wide one, etc...
-ok
Good Luck.
-Thank you very much
Lg tweewielers:
-Thanks, but already the sight
Untiej Mini Racing:
-Not it finished ace?
-ok
Good Luck.
Lg tweewielers:
Untiej Mini Racing:
