I search owner of this minibike.
- doraimontv
- üntiej#21
Degrees of the front-fork:
When putting a straight line up, from the ground, the front-fork must have an angle of 24 degrees at the vertical line.
The distance between the wheels.
From centre to centre: about 730mm.
Front-fork is most of the time between 390 and 420 mm
This is measured from wheelcentre to the above of the fork.
The height from the ground to the backside of the seat is about 600mm
It can be lower, you can take the 600mm as a maximum size.
A little drawing... it sucks... i hope you get it:
- doraimontv
- doraimontv
- doraimontv
- doraimontv
Front fork is "frunza el tenedor"doraimontv schreef:Untiej Mini Racing
I cannot translate this well:
390mm to 420mm you do understand I think.
- I want to draw this for you. Give me a moment.
I'm done.
http://img98.imageshack.us/my.php?image=naamloos4by.jpg
- doraimontv
- doraimontv
- doraimontv
- doraimontv
- doraimontv
