Pagina 1 van 3
Blata elite 14 WRR
Geplaatst: ma 27 okt 2008, 17:07
door coen
http://images.google.nl/imgres?imgurl=h ... %26hl%3Dnl
Wordt deze ook in nederland verkocht? zo ja heeft iemand er 1?
The new Blata Elite 14 WRR 50cc is to be released in early 2007.
Elite 14 WRR 50
Basic Technical Data
Engine
Two stroke Liquid Cooled, 5 port
Number Of Cylinders 1
Size, Capacity 49,9 ccm
Power Output 18 HP at 13 500 rpm
Torque 8 Nm at 12 000 rpm
Carburator PHVB 19 Dellorto
Fuel Admision Carbon Fiber Reed Valve Direct To Crankcase
Ignition Electronic
Starting Hand Pull Type, Manual
Clutch Centrifugal, Friction Automatic
Frame
Welded Of High - Strenght Steel Tubes
Lining Three Parted
Brakes
Front Wheel Mechanical Disc Brake
Rear Wheel Mechanical Disc Brake
Wheels
Front LIGHT ALLOY 6,5" - 63
Rear LIGHT ALLOY 6,5" - 63
Tires
Front 90/65 - 6,5" PMT - T40
Rear 110/50 - 6,5" PMT - T40
or 90/65 - 6,5"
Fuel
Gasoline Mixture Mixture of Gasoline 92 Octane or Higher + 2T Synthetic Oil
Mixing Ratio (After Break In Period)
50: 1
Tank Capacity 1 Liter
Speed
With The
Instaled Ratio up to 50mph(80km/h)
Basic Dimensions
Weight (48lbs.) 22 Kg
Carrying Capacity (240lbs) 110 Kg
Length 945 Mm
Width 470mm
Height 565 Mm
Colors Red, Black, White, Yellow
Pricing will be around $3900.00
Still less expensive that many other Euro brands.
To celebrate the announcement of this release Oz Minimoto is giving away FREE, any Cag aircooled bike with a purchase of any genuine Blata bike in stock for the month of October 2006.
Normal delivery charges still apply.
Also a genuine 50cc top end kit will be avaliable in early 2007 for anyone interested in upgradeing their genuine Blata 40cc bike.
__________________
Thankyou
Darren
Oz Minimoto
Geplaatst: ma 27 okt 2008, 17:09
door kleine_duivel
nog niet gezien.
wel weer lekkere overdreven spec's...
"power output 18hp"
:lol:
Geplaatst: ma 27 okt 2008, 17:15
door DMZohrab
ik ben hem ook all is op het internet tegen gekomen, :-k
hij is vast niet in nederland te verkrijgen anders had ik hem vas twel tegen gekomen..!? :roll:
Geplaatst: ma 27 okt 2008, 17:30
door thomas1991
Bleek toen volgens mij allemaal onzin te zijn.
Gewoon gefotoshoped plaatje. Of gewoon 2x R achter elkaar geplakt :lol:
Ik heb er iig nog nooit een gezien, je ziet wel vaak dat er op de blata blokken BZM 40 of 50cc cilinder worden gezet.
Die foto is trouwens ook de enige foto die er ooit van geweest is.
(was een topic over op een duits forum :wink: )
Geplaatst: ma 27 okt 2008, 17:34
Beetje slimmerik kijk al naar de uitlaat :roll:
Deze kan close?
Geplaatst: ma 27 okt 2008, 19:28
door -René-
in nederland zijn wel gewoon originele blata 50cc cilindertjes te krijgen, duitsers rijden vaak met omgebouwde blata blokjes met bzm kitje erop, deze zijn ook gewoon te bestellen via duitse internetsites
Geplaatst: ma 27 okt 2008, 19:59
door kleine_duivel
die cilinders zijn in mijn ogen nog niet competatief gebleken :wink:
Geplaatst: ma 27 okt 2008, 23:57
door -René-
daar heb jij helemaal gelijk in, maar die zijn ook nog in verdere ontwikkeling wat ik als laatste heb vernomen, tenminste als je het hebt over de blata 50cc cilinders, bzm kitjes heb ik verder nooit in mijn handen gehad...
Geplaatst: di 28 okt 2008, 16:46
door Jarno #23
blata komt binnekort met een nieuwe 50cc voor de b1 :wink: dus maar eens afwachten wat dat gaat worden mar deze bike heb ik ook nog nooit ergens gezien dus kan ook gewoon een omgebouwd bikeje zijn..
maar ik zie op deze bike helemaal geen luchtfilter zitten :roll: :?:
Gr Jarno #23 www.jarno23.tk
Geplaatst: di 28 okt 2008, 21:29
door Blatarac3r
en de carb. ook niet :lol:
Geplaatst: ma 24 nov 2008, 15:02
door wizzlawax
ah, dat blata eerst maar eens met orginele snelle cilinder/ blokje gaat komen zodat bzm geen kans meer maakt :lol: en niet 50cc laat ze maar een 40cc snel maken 8)
Geplaatst: ma 24 nov 2008, 15:47
door ruben4takt
wizzlawax schreef:ah, dat blata eerst maar eens met orginele snelle cilinder/ blokje gaat komen zodat bzm geen kans meer maakt :lol: en niet 50cc laat ze maar een 40cc snel maken 8)
Pas op wat je zegt!!
bzm 40cc is al lang veel sneller gebleken en bewezen dan de blata 40cc.
Groet,
Ruben.
Geplaatst: ma 24 nov 2008, 15:49
door wizzlawax
bzm 40cc is al lang veel sneller gebleken dan de blata 40cc.
Groet,
Ruben.
srry maar dat bedoelde ik juist ook, dat blata maar eens hun 40cc sneller maakt als de bzm :P
Geplaatst: ma 24 nov 2008, 20:54
door kleine_duivel
moet kunnen toch?
als je ziet hoeveel er met tuning nog uit zo'n bzm blok valt te halen,
dan moet er ook een beter standaard blok dan dat kunnen ontworpen :wink:
Geplaatst: di 25 nov 2008, 13:26
door Stastny
Pardon, zijn we het NMC van dit jaar vergeten!
Hier bleken Joey de Laet en Tyrell Bivens met hun 40cc Blata B1 VK menig keer sneller te zijn dan de BZM blokjes.
En wie is er Europees Kampioen in de 40cc geworden?
Juist ja de 40cc Blata Elite 14 WRS.
En wie won de Belgische Kampoienstitel?
Juist ja Jarno van der Loo met Blata B1 VK
