Uniek in Nederland, binnenkort in beperkte oplage leverbaar!
De midi Gp motor, gebaseerd op de Honda NSF 100!
Dit is echter een midi racer op een pitbike basis,super
Uploaded with ImageShack.us
MODEL: GP150R
LENGTH Ã WIDTH Ã HEIGHT:1590 Ã 595 Ã 911mm
WHEELBASE: 1150mm
GROUND CLEARANCE: 123mm
SEAT HEIGHT: 681mm
CASTERANGLE: 23° 36'
DRY WEIGHT: 83.6kg
ENGINE
Displacement:150cc
Engine type: single cylinder, 4 stroke N-1-2-3-4, all up
Box X stroke:60x53mm
Gear:4 speed
Max power:15HP
Start method: Kick start
Start lever: Steel
Ignition: CDI
Cooling type: Oil cooling
Clutch: Manual clutch
Carburetor: Molkt
Ignition: Outer type
CHASSIS
Frame assy: steel
Swing arm: aluminum
Handle bar: aluminum
Throttle assy: aluminum
Clutch lever: aluminum
Front fork:USD type, rebound and compression adjustment length:600mm, stroke:70mm; spring: 18PD, diameter: 45/48mm
Rear shock:rebound and compression adjustment, length: 218mm,stroke:37mm, spring: 1000PD
Clamp: Material: aluminum, color: Ti, silver, black, machining method: CNC
Rim: material: aluminum, front/rear: 2.50-12, 3.00-12
Tire: front/rear: 120/90-12 120/80-12
Sprocket: Front/rear: 16/37T, 7075 aluminum
Chain: 420#, KMC
Brake paddle: CNC, alloy
Brake front/rear:
Disc front/rear: 220/190mm, 4/1 pistons
Exhaust pipe: Material: stainless steel
Muffler:
Material: aluminum, machining method: CNC
Seat assy: foam
Plastics assy: NSF100, fiber glass
Fuel tank: steel
Foot rest: aluminum, CNC machined
